rearend question?... - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2012, 01:03 AM
ok my question is that my truck is a 1991 slivrado that used to be a v6 manual but i swapped in a mild built 350 and a th350 trans would the rearend from the manual trans have any bad effects on an auto trans? like the gear ratio? would it cause my truck to max out at like 70mph and and cause my trans to not shift into 3rd gear and run at high rpms when going down the freeway?
Old 02-26-2012, 06:32 AM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Not an expert here but I'm thinking u went from manual or overdrive to a th350 which is a 1:1 drive gear i believe so yes it can change yer cruise n rpms and yer shift points. Hg
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 02-26-2012, 12:23 PM
How would I go about fixing that would I have to swap out the gears? Maybe swap some out of an older chevy truck that had a th350?
Old 02-27-2012, 02:16 PM
Would a rearend out of a early 80s chevy truck swap in to it with no problem?
S-10 rearend question. tfeverfred Transmission - Rearend 25 09-22-2007 02:49 PM
rearend question gmc stepside Transmission - Rearend 2 11-27-2005 02:31 AM
Jag rearend question 55 F-100 PAUL Transmission - Rearend 3 11-13-2004 05:43 AM
rearend question ricks032003 Introduce Yourself 2 07-27-2004 07:44 AM
rearend question onehot69charger Hotrodders' Lounge 2 04-03-2002 04:08 PM
