rearend recommend?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2002, 07:05 AM
New Member
Post rearend recommend??
I ahve a 69 chevelle malibu with a 327. I dont have posi in the rear but plan to soon. I need coil springs and shocks. right now i have air shocks, are these really worth keepin? I would want coil springs that will lower my rear end so that the tire sits in the fender well nicely. i have 295 50 15 tires. I want springs that will help give me a good jump when i take off. id like to convert it to a 4spd also so when i drop the clutch i dont want the car to sag back then go, i want the front end to lift up somewaht and take off. does anyone know of some good springs and shocks? also if you know of what size i might need too? i dont have much money so i dont want the really expensive ones, just really reliable and good.
Old 11-20-2002, 04:39 PM
Post
You could use the kit that competition engineering puts out. It has the coilover shocks, springs, brackets, hardware, etc. I think it costs about 199.00. The air shocks you mention I would throw out. Those things are horrible. You can't get weight transfer with air shocks. With the comp engineering kit you have several ride heights that you can set depending on your taste and how you want the car to perform. Also, you need to figure out what type of suspension you will want to run in the rear. Stock, ladder bar with a panhard, four link with a diagonal, etc. Once you put the posi in, you want to make sure it hooks up.
