Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rearend Swap
Thread: Rearend Swap
Old 10-11-2011, 02:50 PM
35terraplane's Avatar
35terraplane 35terraplane is offline
Rearend
Originally Posted by oldman w/white 57
Needing to update rearend of my 54 Ford PU. What's my best donor for this swap. Keeping it Ford and springs. Drum/Disc brakes not that important to me
You will have to measure, from backing plate to backing plate to see what you have. then measure from frame to inner lip of fender that will tell you how much space you have to work with. Check your tire at the fattest part. Then go to the local you pick and bring a tape and start measuring. I would put a car rearend in it for the gearing, but you can check the tag to see what you are getting.
You might have t cut the mounting pads off and move them, just don't cut though the housing. If you want different springs you will have to measure what you have then find some the right length, or you can buy a mounting kit.
Bob
