-   -   Rearend Swap (http://www.hotrodders.com/forum/rearend-swap-206918.html)
oldman w/white 57 10-11-2011 01:25 PM
Rearend Swap
Needing to update rearend of my 54 Ford PU. What's my best donor for this swap. Keeping it Ford and springs. Drum/Disc brakes not that important to me
35terraplane 10-11-2011 03:50 PM
Rearend
You will have to measure, from backing plate to backing plate to see what you have. then measure from frame to inner lip of fender that will tell you how much space you have to work with. Check your tire at the fattest part. Then go to the local you pick and bring a tape and start measuring. I would put a car rearend in it for the gearing, but you can check the tag to see what you are getting.
You might have t cut the mounting pads off and move them, just don't cut though the housing. If you want different springs you will have to measure what you have then find some the right length, or you can buy a mounting kit.
Bob
cobalt327 10-11-2011 04:03 PM
Here are a couple links w/various rear end widths.
http://www.quickperformance.com/Tech...us_measure.htm
It's not stated, but this one is also the width from the wheel mounting surfaces- http://www.carnut.com/specs/rear.html
prostreet6t9 10-11-2011 07:43 PM
My buddy just did a 55 ford truck swap. He used a 9" out of a 78 F150. I believe the 78 diff was 4"ish wider but it worked out good with his wheel and tire combo.
S10xGN 10-11-2011 09:35 PM
Explorer 8.8"'s are good and cheap, may need to move the perches though...
Russ
