Rearend Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2011, 12:25 PM
Rearend Swap
Needing to update rearend of my 54 Ford PU. What's my best donor for this swap. Keeping it Ford and springs. Drum/Disc brakes not that important to me
Old 10-11-2011, 02:50 PM
35terraplane's Avatar
Rearend
You will have to measure, from backing plate to backing plate to see what you have. then measure from frame to inner lip of fender that will tell you how much space you have to work with. Check your tire at the fattest part. Then go to the local you pick and bring a tape and start measuring. I would put a car rearend in it for the gearing, but you can check the tag to see what you are getting.
You might have t cut the mounting pads off and move them, just don't cut though the housing. If you want different springs you will have to measure what you have then find some the right length, or you can buy a mounting kit.
Bob
Old 10-11-2011, 03:03 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Here are a couple links w/various rear end widths.
http://www.quickperformance.com/Tech...us_measure.htm
It's not stated, but this one is also the width from the wheel mounting surfaces- http://www.carnut.com/specs/rear.html
Old 10-11-2011, 06:43 PM
prostreet6t9's Avatar
Differential/Driveline
My buddy just did a 55 ford truck swap. He used a 9" out of a 78 F150. I believe the 78 diff was 4"ish wider but it worked out good with his wheel and tire combo.
Old 10-11-2011, 08:35 PM
S10xGN's Avatar
Gotta love a turbo!
Explorer 8.8"'s are good and cheap, may need to move the perches though...
Russ
456 gear swap to 373 in 8.5 rearend, carrier swap? leslie61 Transmission - Rearend 3 07-19-2009 03:45 PM
rearend swap pettybluedart Transmission - Rearend 2 06-16-2008 06:34 PM
Tranny swap/ rearend swap? aggar Transmission - Rearend 2 03-16-2008 03:07 PM
rearend swap johnnyblaze Transmission - Rearend 11 03-05-2008 07:12 PM
55 Rearend swap Dicks55 Transmission - Rearend 2 11-05-2006 05:29 PM
