Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rearend swap for 55 GMC Truck?
Old 05-04-2013, 05:41 PM
big gear head's Avatar
big gear head big gear head is online now
High Performance Rear Ends
I don't think you will find any rear end that will bolt in. You will have to weld spring perches to any rear end that you find. You need something that is the correct width that you can put spring perches on. The Nova and 1st gen Camaro rear ends are usually about right for this swap.
The Following 2 Users Say Thank You to big gear head For This Useful Post:
Crosley (05-04-2013), DLC67 (05-04-2013)
