Rearend swap for 55 GMC Truck? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2013, 12:16 PM
Car Nut
I have a 55 GMC that I am installing a 455 ci Olds in, with an AOD.
When I go into the truck rearend, if I find serious issues; am I better off to replace it with a limited slip from a car (rather than rebuild it)?
Any ideas which GM rearends would bolt under the earlier truck?
Thanks!
Old 05-04-2013, 05:41 PM
big gear head's Avatar
High Performance Rear Ends
I don't think you will find any rear end that will bolt in. You will have to weld spring perches to any rear end that you find. You need something that is the correct width that you can put spring perches on. The Nova and 1st gen Camaro rear ends are usually about right for this swap.
The Following 2 Users Say Thank You to big gear head For This Useful Post:
Crosley (05-04-2013), DLC67 (05-04-2013)
Old 05-04-2013, 05:58 PM
Car Nut
Thanks. I've done the spring perch thing before. Putting a 96 Cobra rearend under a 67 Mustang.
Old 05-04-2013, 07:13 PM
RWENUTS's Avatar
73-87 chevy truck bolts in. THe perches are almost perfect. Just 1/4 inch difference in overall width.
48 gmc truck to s10 frame swap pioneer-auto Engine 1 06-03-2009 08:09 PM
1990 GMC 1500 rearend swap 90GMCVortec Transmission - Rearend 5 01-06-2009 10:08 AM
rearend swap 56 chevy truck StLouisDave Transmission - Rearend 1 10-07-2008 07:44 PM
chevy truck rearend swap OldSkooLNewbie Transmission - Rearend 0 01-18-2006 09:07 PM
rearend swap 56 chevy truck ksm Transmission - Rearend 4 06-25-2003 08:24 AM
