rearend swap for a nova - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2004, 10:43 PM
nova63and66's Avatar
New Member
I have a 63 nova it came with a 4-lug rearend and i was wondering if anyone knows what car would be a direct swap or what year and cars come with a 51" width rearend. it doesnt have to be a direct swap but if i could find one with a 51" width i could make it fit.
any info would be great,
thanks
Old 01-10-2004, 04:09 AM
OddRodder's Avatar
CORNFED and INBRED !?!
I believe that an S-10 rearend is very close to that width!
Old 01-12-2004, 09:56 AM
Don't laugh, look at a Ford 8.8. They should be right around there and Explorers used rear disc.
The 8.8 is equivalent to a 12 bolt. In fact, I've read that all the bearing in a 8.8, directly interchange with a 12 bolt Chevy!
Old 01-12-2004, 11:29 PM
'65-'67 Chevy II 5-lug axle assembly should fit a '63.
Old 10-24-2005, 01:17 PM
Mustangsaly's Avatar
Please use the PM system to offer parts to a board member.... moderator
Mustangsaly
Old 10-24-2005, 01:26 PM
thanks
I would just re drill the axles and brake drums......to the stanard 5 on 4.75 Chevrolet 5 lug pattern ...
Moser Engineering ( and lots of others ) can do this....
I have used Moser before......and always satisfied with the work, the price and the turnaround time.....
http://www.moserengineering.com/mose...opservices.htm
Old 11-06-2005, 12:57 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
thanks
I think you mis-measured that width. There is nothing that is that narrow except little English sports cars..
S10s are about 57.....
You are probably more like 56 wide.
Has anybody out there actually measured a 63 Nova?????
What's the spring width too.?????
Old 11-06-2005, 06:44 AM
He most likely made the mistake of measuring from the backing plate....to the backing plate.
The most accurate way is like this........
The other way will not take into account the difference in widths of the various brake drums. Some are 1 and 1/2 and some are as wide as 3 inches. The difference can throw the TRUE reading off by 2 or more inches.
DEUCE.........
Old 11-09-2005, 05:16 PM
jbon64
good call duece, you just saved me a trip to the garage .....my 63 had a different measurement
Old 11-09-2005, 08:51 PM
A re drill is an easy way to go. Go buy a rear drums for a 64-67, pull the axle knock out THREE of the four studs. Bring them to a machine shop with the eight new studs have the flanges re drilled and the studs installed if you have a drill press you can do it at home, just place the drum over the axle, using a transfer punch mark the four new holes drill install studs. I will be doing this with the wifes 62.
Other options are
1. 64-67 direct bolt in
2. S10 pickup they are about 55" flange to flange (about 2" narrower or so)
3. S10 Blazer, 58-59, can't remember about 3/4" wider than stock.
The s10's use a 7.5/7.625 ring gear, not real strong, will hold up to small v8 300 or less hp. Novas are light so this could be a good choice. I will be using a Blazer rear in the 62 on down the road, with Camaro disc's (direct bolt on).
Old 11-10-2005, 06:34 PM
Check Your PMs
ba21939@yahoo.com
Brock
