rearend torq specs - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2006, 08:00 PM
rearend torq specs
whats the rearend bolts on a 92 chevy truck 1/2 ton torq at
Old 06-27-2006, 08:42 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
which bolts on the rear end?
lug nuts, carrier , ring gear?
Old 06-27-2006, 09:38 PM
the u bolts that hold the rearend to the springs
I need some input on putting a Ford rearend under a 1972 Dodge Dart onebadmerc Transmission - Rearend 7 12-21-2005 11:30 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 07:23 PM
Specs on a Ford 8.8 rearend Pencilneck314 Transmission - Rearend 0 11-17-2003 05:57 PM
IFS Must II Torq specs Help 39chevy Suspension - Brakes - Steering 1 10-26-2003 01:49 PM
rearend for a Model A 30coupe Transmission - Rearend 10 11-25-2002 09:04 PM
