I just traded for a 454 4 bolt main block and am looking at rotating assembly kits. I know that Procomp in a lot of circles has not had a very good rep. I am building this on a budget or as much of one as you can really do with a bigblock! Any experience with this kit, seller? Any other suggestions in the same or close price range?
Thanks! That does look like a better kit. I wonder if he sells it with a flywheel setup instead of the flexplate. Its funny, my first BB build I did not spend wisely. I did wined up with a 400 rwhp 454. But doing more research I could have done a 496 for as much as I had in the 454 or maybe less!!!
glad i could help! if you buy something like this kit.. be sure to have everthing check before you ever build... it will save you Dollars in the long run!!
JP
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
