Reason why most wet/dry papers stop at P2000? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2012, 10:10 AM
Seems like many wet dry sandpaper manufacturers quit at P2000. I see that one goes to P3000, so it's possible to go higher but my question is this... is it a technology reason (would require technology that is expensive or not available to produce finer than P2000) that they stop at P2000 or is it because that's really as high as a person needs before buffing? Maybe the tradeoff of time makes it better spent buffing rather than sanding after P2000?
I realize 3M now goes to 2500 but it seems like a lot of manufacturers stop at 2000. Curious the reasoning behind this by those who actually do sanding (like myself).
Old 03-07-2012, 10:23 AM
cyclopsblown34's Avatar
Colorsanding painter
My guess would be the expense to create abrasives that fine. I've found 2500 in brands other than MMM but they're few and far between. I think one of the brands I found it in was Mequiars which is now a division of MMM
Old 03-07-2012, 10:52 AM
zbhover's Avatar
V8 Beetle & Hovercrafts
I'm also into woodworking, more specifically wood turning. To get a nice glass smooth finish I'd sand up to 2000 grit and then switch over to Micro-Mesh, which gets SUPER fine, 12,000 grit I believe. Its a bit pricey though, and might cost a bit much to use for sanding body panels.
I know its used a lot in wood working, but I think the solid surface counter top people use it too.
Here are a couple links:
micro mesh manufacture page
5" disk assortment
Sanding Pads
sanding kit
Zach B
Hovercraft & Woodworking Site:
zbcreations.com
V8 Beetle Site:
v8beetleresource.com
Old 03-07-2012, 11:35 AM
ogre's Avatar
the 'Duracell Project'
it's called buffing compound
Old 03-07-2012, 11:49 AM
If you really want to experiment with finer grit paper, get into model car building. They use anywhere from 6000-12000 before polishing. Luckily they don't have much surface area!
Old 03-07-2012, 12:12 PM
The last lacquer job I did (about 15 years ago) I was at the paint store talking about it and the guy goes in the back and hands me a few sheets of 15000 grit. Yes, fifteen thousand grit. He had gotten it from someone in the air craft industry, it was for repairing plexiglass windows. It was 3M, and I have never been able to find any since those pieces he gave me that day. When I painted that car I wet sanded it up to 2000 (it's all that was available) then took out that 15000 and it was AMAZING! I simply sanded it well and hit it with the buffer with fine compound and it was a MIRROR with one pass of the buffer!
Damn that stuff was awesome.
Old 03-07-2012, 12:40 PM
zbhover's Avatar
Brian, that got me thinking, I remembered seeing windshield restore kits in my wicks aircraft supply catalog. It looks like they use micro mesh now too:
Wicks Aircraft Supply Micro Mesh Kit
Wicks Aircraft Supply Orbital Windshield Restore Kit
Zach B
Hovercraft & Wood Working Website:
zbcreations.com
V8 Beetle Website
Old 03-07-2012, 12:56 PM
3$ has micron grade film discs line (not wet dry if I recall) that goes to 1u but I'm not sure what grit that would be. I have some in 15u which is 1200 grit approx. They're made for the solid surfaces industry and are called 366L. They work pretty well for paint when I last used them but I prefer to wet sand vs using a Dynabrade (Don't like dealing with pigtails and I get a better off the sander finish without the orbit).
As far as the Micromesh stuff, their grading is different. It's a good product no doubt but I've used all of their finer grits and it's not the P scale. Their 3200 is really more like P320 in my experience (side by side comparison). Their 36,000 (I think that was the highest) was probably like P2000. So I take their grit scales with a grit of salt
Old 03-07-2012, 01:03 PM
Where you at Funk? Slo Reilly usually keeps MMM 2500 grit in the half sheets.
Old 03-07-2012, 01:13 PM
Slo Reilly lol. Thanks and You're right, I use them when I get 3M Imperial. I've got a PBE account with them. Pricing is a little on the high side.
It's not so much a sourcing problem as much as a why question.
Seems like most abrasive brands stop at P2000. Even though some MFG's go to P3000 but that's the highest I've seen in a P graded wet/dry and it's almost treated like a novelty item more than something that's used. I'd think if it were possible to easy get a P4000 or higher finish off the sander and without scratches beyond the P4000 grit, it'd be a time savings vs having to buff courser sanding scratches.
Old 03-07-2012, 01:21 PM
You're right on about the finer sanding reducing the buffing/polishing.
Old 03-07-2012, 09:35 PM
The hobby shop stuff might be easiest to to get.
http://www3.towerhobbies.com/cgi-bin...?&I=LXXMZ3&P=7
I think the finest grit inthe pack is 0.5micron?
reference:
http://www.treeringsociety.org/TRBTR...ol51_43-46.pdf
Old 03-07-2012, 09:59 PM
Ok just found an interesting little grit comparison chart. Micromesh is finer than I had given credit for above but I still question it. It really seems like their grit numbers were pretty exaggerated by the old feeler test. I wish they'd use real P scale numbers. Micron is also a good measure (probably the best since it's absolute). Looks like P2500 is 8.4u. So 1u would probably be around P4000 or maybe a little finer.
http://www.fingerlakeswoodturners.co...Comparison.pdf
Old 03-07-2012, 10:11 PM
put up or shut up
trizac 3000 is nice to have around and easy as pie. a bit pricey though.
Old 03-08-2012, 07:49 AM
When I used a random orbital it was at the top of my list of good products. That and Mirka Abralon, Sia Air, Fandeli Supreme Foam, Klingspor has a new similar product. They all helped to reduce the scratches. But at $4-$8 per disc!! On the same token, the discs lasted about 3-5 times as long as wet/dry sheets. The foam seemed to help. I just ordered some P4000 Mirka Abralon for my 1/3 sheet inline a couple days ago. I'll be using that again. It's $5 per 1/3 sheet! Ouch. I like the 20-30 cents for 1/3 sheet of wet dry paper a little better.
I'm always wondering about the trade off on when to start buffing and leave sanding. I've got a feeling P2000 and a good cutting compound is probably faster than sanding finer and that's why there's no P4000 or P12000 (real 12000) in wet dry.
Here's one reason for $5/gal. redsdad Off-Topic 0 01-23-2012 07:06 AM
There is a reason for guards Kevin45 Off-Topic 26 09-15-2007 02:52 PM
some reason JJht.rd Engine 2 12-14-2005 12:01 AM
Does The "Stop Leak" Stuff Stop the Rear Main From Leaking? daveh Engine 7 08-02-2005 09:43 PM
NO reason know this but... bullheimer Hotrodding Basics 18 06-01-2004 06:18 PM
