ReAssembled Engine Making Noise Not Running Right HELP!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2005, 06:48 PM
Last journal entry: Rear End Disassembly
I bought an older bike that was dissasembled. The engine was incomplete from the cylinder block on up. I went ahead and finished everything off and tried starting it today. It had trouble starting so I jumped it. When I finally got it running, it sounded like one of the cylinders almost had no exhaust it was so loud. I had it running for a little while but if I let off on the throttle it would just die.
After a while of jumping it to try and get it running for a decent amount of time, I took it for a ride. Every time I pulled in the clutch it sounded like it would die and when I shifted and released it basically jumped itself.
Now I can get it started but the noise sounds like something is wrong. Does this noise relate to the reason its not staying started. Because once i get it runing and try to let off completely on the throttle, boom its dead. I was thinking maybe a ring was bad but wouldn't it still run if one was bad?
Any help would be appreciated.
Thanks
David
Old 10-09-2005, 07:24 PM
docvette's Avatar
Wiki Edits: 12
moer info..
Doc here
Not enough info to even begin to make an intelligent diagnosis..
IS it a 2 stroke, or 4 stroke..?
What does the sound , sound like..knock, rattle, ping, pop, etc..single or double knock, deep knock or light knock..
Rings=loss of compression and USUALLY smoke..
Tell us more, and we'll tell you more..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 10-09-2005, 10:08 PM
It's hard to say what kind of noise it is because I've never heard anything like it before. When i first started it I had the exhaust off. I thought that it was real loud because of this. But then I put it on and noticed that coming from one??????????? of the cylinders a sound almost like the exhaust WAS off. Almost like every time it fires its just a real loud burst. P.S. every cylinder is firing as i can feel it from the exhaust.
The thing is that this problem is obviously affecting its running condition. It's not just a knock that is there whenever I would drive it, it seems to be causing its demise.
I'd like to add that when I tried jumping it for a while, it would jump and sound like it was started but giving it throttle or pulling the clutch in would do nothing.
When I finally did get it started it was real hard to keep going, and I held it revved for a while. Well for a second the loud popping actually went away and I got more rpm capability but then I heard backfirig and it soon started to make the loud noise again. And no matter how long i kept it up it would give way when I let off the throttle. Then starting it was another issue
Also, when one piston ring was installed it was just sligtly barely bent, it went in ok but I dont know if this could be a factor. I was told by a mechanic that it shouldn't cause anything so?
I wish I could put a sound clip online
Old 10-10-2005, 03:50 AM
valve stuck open or a shot head gasket?
Old 10-10-2005, 04:50 PM
brand new head gasket was installed. as far as the valve, maybe some engine gurus can let me know if this sounds like a similar problem and if the results are similar.
Old 10-10-2005, 05:59 PM
i can buy a head off a running bike for around $50 if this could solve things. id rather be able to figure it out on my own without just replacing the head though.
setting points on sb chevy frackster66 Electrical 23 01-07-2014 06:50 PM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
TH350 making whinning noise! "SLOWMOE" Transmission - Rearend 4 06-02-2004 01:27 AM
Engine running really hot!! zeeman19 Engine 18 11-25-2002 01:09 PM
engine stops running after a few minuits rrp358 Engine 1 07-31-2002 01:43 PM
