Reattaching underhood structure - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2012, 07:12 PM
mitmaks's Avatar
Last journal entry: Grille
I have a hood that has underhood structure that has separated. It was glued on like most hoods are. What would be good glue to reattach it back on there?
Old 08-20-2012, 07:42 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
Is it a metal hood or fiberglass?
Old 08-20-2012, 07:43 PM
mitmaks's Avatar
Metal hood
Old 08-20-2012, 08:22 PM
put up or shut up
anti flutter foam or urethane 2 part seam sealer. Some people use the expandable foam that you can use for door beams but you have to estimate how much it will expand on you or you can cause a teepee effect.
When doing this you have to make sure it really gets in there as opposed to just being on the outside where you can see it.
Old 08-23-2012, 08:10 AM
deadbodyman's Avatar
Wiki Edits: 11
If your NOT taking out the old stuff and just want to reattach it you can use super fast urathane for gluing in windshields...worked for me.
The Following User Says Thank You to deadbodyman For This Useful Post:
mitmaks (12-30-2013)
Old 12-29-2013, 11:24 PM
mitmaks's Avatar
I might try some JB weld.
Old 12-30-2013, 10:26 AM
You don't want to use JB weld, it's too hard. Originally as Henry said it was "anti flutter" foam, a soft foam to allow movement. "Gluing" it to the skin is not good because they move indepentantly from one an other a little, you need to allow that movement.
Old 12-30-2013, 06:35 PM
mitmaks's Avatar
Thanks. I just wanted something that would hold on there. Hood I got is like 20 year old but all of the underside is detached so I just want to make sure it won't happen again.
Old 12-30-2013, 08:15 PM
mitmaks's Avatar
Looks I'll have to buy expensive applicator gun just to use this product.
Old 12-30-2013, 08:31 PM
mitmaks's Avatar
Might give this a try.
Old 12-30-2013, 08:39 PM
This is true and exactly how I do it on door skins. I cut the foam from the skin, then put a dab of urethane on it when I put the new skin back on.
Body Structure Start?/ pittkdude Body - Exterior 2 11-06-2009 06:38 AM
29 chevy coupe wood structure marblemanor Body - Exterior 4 10-22-2007 09:04 AM
Inner Structure for stiffness/Upholstery 35WINDOW General Rodding Tech 8 07-26-2007 08:00 AM
problems reattaching ladder bars GMR Suspension - Brakes - Steering 6 03-08-2007 12:42 PM
replacing wood body structure in the '29 dodge 427v8 Interior 6 02-17-2006 08:34 AM
