Rebuild 400 or search for 455 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2010, 04:20 PM
I am not much of an engine guy I have a 71 Lemans Sport, I was searching for a 455 but today i was talking to a guy and he said they are hard to come by so he offerd me a two 400. I am looking for a crusier mainly but somtheing that if i punch the gas i want it to go. This is what he offerd me let me know what you think
1)
* 400 block bored, honed, decked and align honed
* Performance camshaft:
o 214/224 @ .050 (specs may change)
o .465 lift
o 112 lobe center
* New cam bearings
* Balanced rotating assembly with balancer
o Reground 3.75" stroke crankshaft ( add 350.00 for new)
o Forged rods with ARPR rod bolts
o New performance bearings
* Performance pistons with MollyR rings( add 400.00 for forged)
o 9.3 to 1 compression ratio
* New timing set
* New high volume oil pump
* New performance gasket set
Pontiac Heads includes:
* 2.11/1.77 new stainless valves
* Aluminum heads available (-add 2000.00 )
* Bronze guides
* 3 angle seats
* Matching springs
* New push rods and stamped rockers (roller rockers add 350.00)
* Painted Pontiac blue
* Bowl porting
* Stage 2 porting ( add 695.00)
* Dial in cam
400 HP
$3995.00+core
or
2)
- 1972 400 with an HO package for $2510
- stock built 340 HP
he did not send me all the detalis but is there anything i should ask him?
or
3)
Do i search for a 455 or better deal?
Old 10-25-2010, 05:04 PM
If you're just wanting to build a street car, the 400 will provide plenty of power. It all depends on what you're going to use it for. A 500hp N/A 400 will be more for the strip, but a 500hp N/A 455 will be a lot tamer on the street. If it's going to be less than 450hp, I would just build the 400.
Old 10-25-2010, 05:14 PM
Last journal entry: It Will Work
Sounds like a infomercial. Don't those engine kits cost about $500?
Old 10-25-2010, 05:20 PM
I am not buying a kit i am buying a whole engine. Which option do you think would be a good choice?
Old 10-25-2010, 05:23 PM
I wouldn't buy either in a bad economy.
Old 10-25-2010, 05:29 PM
If you have the extra money, I would go with the first one. The second one is a stock build so it's going to have factory Pontiac rods that are good to about 5500rpm. The first one has a little insurance in the rotating assembly.
Old 10-25-2010, 05:32 PM
What kind of warranty does it come with?
Old 10-25-2010, 05:36 PM
I'm saying you would have a little peace of mind knowing it is built for punishment. Also, make sure whoever did the machine work knows the ins and outs of a Pontiac. They are a whole different beast than a Chevy.
Old 10-25-2010, 05:37 PM
the first one comes with a 3 unlimited year and the send with a 7 year 100,000
Old 10-25-2010, 05:40 PM
Who is offering that kind of warranty on a Pontiac engine?
Old 10-25-2010, 05:42 PM
the shop that is building it for me is offering it.
Old 10-25-2010, 05:44 PM
It's not a trick queston what is the shops name?
Old 10-25-2010, 05:47 PM
Precision Engine
Old 10-25-2010, 05:50 PM
Sounds like a unbelievable warranty since people on the Pontiac BBs are blowing up Ponitacs every other day.
Old 10-25-2010, 05:58 PM
so what option do you think is best even if i took the stock could i do the upgrades over time for the same price or less
stock rebuild sbc 400 eatonde Engine 8 12-07-2008 06:08 PM
400 cid SBC Shades_o_Grey Engine 20 02-04-2008 12:28 PM
sbc 400 rebuild camarodriver Engine 1 02-22-2006 08:39 AM
400 rebuild cost wayneair Transmission - Rearend 1 02-02-2006 11:37 AM
Turbo 400 rebuild costs $$ ? mark2002 Transmission - Rearend 9 10-08-2003 09:06 PM
