rebuild hay truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2008, 04:17 PM
rebuild hay truck
hello im new here but iv got an old 78 chevy 3 ton tandom axle truck with a 427 stock motor . after i blew the the old piece of **** 97 ford f350 460 motor iv decided to go back with my old 3 ton . iv always wanted to make a beast hay truck but dont know wat i should do so i found this site . now on to the truck the motor was fine when i bougt the ford but just stoped usin it and when i wen to start it , it wouldnt so i went and bought a carb and it fired right up and its still as strong as when i left it but im going to replace it or rebulid it and iv always herd that a 427 stock would always out pull a stock 454 and i guess thats why they used them in the trucks but i was wondering wat kind of motor i should go with i mean im willing to spend 30000 k on the truck so wat ever block i should start with and work with i would like to know wat u guys think i was even looking at some merlin blocks for it but watever gets me a **** load of tq. so thanks for reading this
Old 07-05-2008, 07:14 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
If you want a buttload of torque, then let me suggest a Caddy 500.
The 427 isn't any better or worse than the 454. The 427 in your truck is most likely a tall deck (10.2" instead of the more common 9.8). The 427T as its called uses the same stroke and bore as the old-school 427, but the taller deck allows for taller pistons and four rings instead of 3. The 427 has potential, but the bottom line is; cubes are king. The reason people think 427s are so much more potent than 454s is mostly because of when they were produced. 427s were used in the late 60s muscle car era when HP numbers were grossly inflated, and 454s were produced mostly in the 70s and 80s with low compression for smog compliance. But, built the same way, the 454 will beat a 427 anyday because of the extra cubes.
There is no reason you can't make a potent performer from your 427. Just remember that it is most likely the 427T version, so anytime you are looking for intakes, pushrods, connecting rods, pistons, etc, you have to take the taller deck into consideration. A few parts are out there, but not as plentiful as for the "regular" big blocks.
The reason I suggest the Caddy 500 is because of its HUGE torque potential. In a well-tuned stock form, many of them put out 500+ lb ft of torque. Careful porting, cam choices, and other little bolt ons can easily push that to over 600 lb ft. I had a very mild stock rebuilt 500 with an "RV" cam, some mild head porting, and I was making an estimated 575 at the crank.
Old 07-05-2008, 07:15 PM
Its a tall deck block from the factory I think you can make up to a 540 out of the stock block.
Shane
Old 07-05-2008, 07:16 PM
curtis73's Avatar
Wiki Edits: 16
Shane
502 is about as far as I'd go. 540s almost always require an aftermarket block with more room for boring. 60-over is about as much as you can get from a 427T. Plus without the wider pan rails of an aftermarket block, its tough to fit a super long stroke in there.
Old 07-05-2008, 07:24 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
No replacement for displacement..but then a stroker kit will set you back about 2000 or so and with machine work I would figure about 5000 total to build a big inch motor for that truck..probably need to start with a 454 block to get there..what saves you is that the small heads will work along with a stock intake as we won't be turning that motor that hard as we want to get the torque built by 3500 rpm or so..
By the time you get it done in a chev block I would get myself a 500 Cad and drop in there as those will give 500 ft lbs stock..and the adapters are easy to come by..
Sam
Old 07-05-2008, 07:52 PM
curtis73's Avatar
Wiki Edits: 16
Or what about a 12v cummins. A little wrench-turning and you're looking squarely at 1000 lb-ft.
Old 07-05-2008, 08:03 PM
http://www.speedomotive.com/s-7-big-block-chevy.aspx
Old 07-05-2008, 08:34 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
I'm thinking this person could also be the one that posts on here as Thumper_Pumper. His name and location provide clues.
If he is the same person as the above named then he outta be quite familiar with a high output Dodge Cummins.
Old 07-05-2008, 09:03 PM
DoubleVision's Avatar
If you want torque in a gas engine, then go with a 455 olds, pack in a RV cam, a Q-jet carb, a set of headers and up the compression ratio to around 9.5:1, and you got all the torque you`ll ever need.
My new(used) truck 1931 steve Hotrodders' Lounge 5 09-02-2006 12:54 PM
Diesel truck, should I buy it??? 1931 steve Hotrodders' Lounge 4 08-07-2006 08:34 PM
1951 Truck For Make A Wish MINING CAMP Hotrodding Basics 0 05-08-2006 08:00 PM
Swapping a Muncie SM465 to a TH-350 on a FS Chevy Truck TL-Iguana Transmission - Rearend 1 08-22-2004 06:54 AM
head rebuild in truck? mshellw Engine 5 07-24-2004 12:07 PM
