You will get new lifters in a master kit. NEVER re-use hydraulic lifters. The cast savings (?) has a habit of returning and taking a big bite from your wallet side.
First thing you need to do is have a competent machine shop look at those heads. There is a problem and don't be surprised if it estimates out well over $300.00. As for a kit Northern Supply, PAW, Summit, JEGS. All market them. Stock kits contain pretty much the same quality parts. On a driver such as yours, I would order a flat top piston kit with a cam delete (use your cam). A double roller t-chain, better oil pump (M55-A) and brass freeze plugs. I used to sell a bunch of these and if you shop wisely there are deals out there. FIRST DO THE HEADS. Then check for bore problems. If it needs bored, do it. Nothing worse than a oil burning rebuild.. |
If you are going to try to build some H.P., an aftermarket crank, P.M. rods, hypereutectic pistons, and a good balance job are good investments in a 350-400h.p. smallblock.
Take Bob's advice though, bore the block and start fresh. Oval cylinders and round rings will never seal adequately! |
P.M.=powdered metal rods they are production pieces that are rated for 450h.p.
SCAT is making some better quality cast cranks that are inexpensive ($150 range) that should hold up well in that h.p. range also! |
check out this deal i wonder if they will delete the cam or is one of the ones they offer in the upgrade something close to what i want..
http://www.northernautoparts.com/Pro...?ProductId=148 |
