-   -   Rebuild kit for 700r4 (http://www.hotrodders.com/forum/rebuild-kit-700r4-226834.html)
hman17024 12-04-2012 08:06 PM
1 Attachment(s)
I bought a rebuild kit from Advance auto parts for 130 bucks and it seems to have every thing. It's a Proking rebuild kit. It says it was made in Canada I keep hearing that made in china junk is a waste of money and time. Any one one have any suggestions as far as rebuild kits. I've never rebuilt a 700r4 so I don't know which kit I should get or if mine is fine. Any replays or suggestions are appreciated.
BOBCRMAN@aol.com 12-05-2012 04:36 AM
700R4 is not a trans to learn on. MANY changes and updates were done to these over the years.
Rebuild kits are packaged by only a couple of places and sold under many different brands, using seals and pieces from several sources.
poncho62 12-05-2012 04:53 AM
Pro-King
dogwater 12-05-2012 05:51 AM
If I were you I'd take that one back an get a more compleat kit. I rebuilt mine using a kit I got from 700r4l60e. It was around 500.00. Plus if you call them they'll make you a kit based on what kind of HP you have & how you drive your car. I have alot of info. such as books an research I found on the web. And a few do's an dont's. I live not to far from you, at Medina lake. PM me if you want some help.
SSedan64 12-05-2012 05:54 AM
Info last Post here >> http://www.hotrodders.com/forum/700r...ml#post1619292
hduff 12-05-2012 05:05 PM
I have a 700-R4 that may need some attention soon. Don't you need a few $pecial tools to work on the transmission?
Jake_Dragon 12-05-2012 06:14 PM
Just had mine done for me $750
C-10 12-06-2012 10:52 AM
A few, yes.
Clutch piston spring compressor
Low-reverse spring compressor
Snap ring spreader pliers internal/external
Lip seal tool
Lip seal install cones
Input shaft seal sizer if applicable
Pump puller
Bushing cutter
Bushing drivers
Probably forgot a few.
C-10 12-06-2012 10:55 AM
Originally Posted by hman17024 (Post 1619169)
I bought a rebuild kit from Advance auto parts for 130 bucks .
That's known in the trade as a 'paper and rubber kit'
It's a good start.. ;)
hduff 12-06-2012 11:03 AM
Originally Posted by C-10 (Post 1619806)
A few, yes.
Lip seal tool
Pump puller
Bushing cutter
Bushing drivers
Yeah, it didn't seem like a do-it-yourself job unless you have access to the right tools. Transmissions and diffs are the only two parts of the car that I pay someone else to work on and I'll probably continue that practice.
SSedan64 12-09-2012 06:12 AM
Geezz, they charged $130 for a $30 Kit? :eek: I hope the Frictions/Steels were on the other side of that.
hman17024 12-09-2012 06:21 AM
1 Attachment(s)
It came with all the gaskets and rubber o rings 3-4 gear clutch paks ,tranny fluid filter, steel band and some other stuff I haven't looked at yet
hman17024 12-09-2012 06:24 AM
Having trouble uploading the rest of the pics from my iPhone or maybe I'm doing some thing wrong:confused:
Crosley 12-09-2012 08:59 AM
Transtec is common brand product. I use TransTec items every day at work.
I would toss the cork pan gasket out, I prefer Farpak gaskets or the brown paper equal to Farpak. They are covered in an adhesive to aid in sealing the pan
hman17024 12-15-2012 06:25 AM
Transmission rebuild kit
1 Attachment(s)
Hopefully all the pictures uploaded this time
