Rebuild kit for 700r4
I bought a rebuild kit from Advance auto parts for 130 bucks and it seems to have every thing. It's a Proking rebuild kit. It says it was made in Canada I keep hearing that made in china junk is a waste of money and time. Any one one have any suggestions as far as rebuild kits. I've never rebuilt a 700r4 so I don't know which kit I should get or if mine is fine. Any replays or suggestions are appreciated.
| The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post: | ||
hman17024 (12-05-2012) | ||
Ontario Rodders |
| The Following User Says Thank You to poncho62 For This Useful Post: | ||
If I were you I'd take that one back an get a more compleat kit. I rebuilt mine using a kit I got from 700r4l60e. It was around 500.00. Plus if you call them they'll make you a kit based on what kind of HP you have & how you drive your car. I have alot of info. such as books an research I found on the web. And a few do's an dont's. I live not to far from you, at Medina lake. PM me if you want some help.
Info last Post here >> 700R4 is stuck in first gear.
I have a 700-R4 that may need some attention soon. Don't you need a few $pecial tools to work on the transmission?
Just had mine done for me $750
Clutch piston spring compressor Low-reverse spring compressor Snap ring spreader pliers internal/external Lip seal tool Lip seal install cones Input shaft seal sizer if applicable Pump puller Bushing cutter Bushing drivers Probably forgot a few. |
It's a good start..
| The Following User Says Thank You to C-10 For This Useful Post: | ||
hman17024 (12-07-2012) | ||
Yeah, it didn't seem like a do-it-yourself job unless you have access to the right tools. Transmissions and diffs are the only two parts of the car that I pay someone else to work on and I'll probably continue that practice.
Geezz, they charged $130 for a $30 Kit? I hope the Frictions/Steels were on the other side of that.
It came with all the gaskets and rubber o rings 3-4 gear clutch paks ,tranny fluid filter, steel band and some other stuff I haven't looked at yet
Having trouble uploading the rest of the pics from my iPhone or maybe I'm doing some thing wrong
Transtec is common brand product. I use TransTec items every day at work.
I would toss the cork pan gasket out, I prefer Farpak gaskets or the brown paper equal to Farpak. They are covered in an adhesive to aid in sealing the pan
At the Bonneville Salt Flats, first gear is known as 130 mph. |
| The Following User Says Thank You to Crosley For This Useful Post: | ||
hman17024 (12-09-2012) | ||
Transmission rebuild kit
Hopefully all the pictures uploaded this time
| 1986 700r4 trans rebuild kit rec? | bigalow | Transmission - Rearend | 1 | 12-10-2011 07:34 PM |
| 700R4 rebuild kit | fierosum | Transmission - Rearend | 6 | 08-28-2010 10:04 AM |
| 700r4 Rebuild Kit--do I need all of these parts? | wild_man84 | Transmission - Rearend | 4 | 01-18-2009 10:21 AM |
| Which Rebuild kit for a lot of2-3 and 3-2 shifts for 700r4 | wild_man84 | Transmission - Rearend | 2 | 01-16-2009 05:54 AM |
| shift kit rebuild kit help | roy383ci | Transmission - Rearend | 1 | 03-26-2005 07:17 AM |
