Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rebuild Kits
Thread: Rebuild Kits
Old 06-04-2007, 04:26 PM
HalfOunce HalfOunce is offline
I would wait until i had a machine shop check the block and crank both before ordering the kit.... Then once you know how far everything needs to go, order the kit......Now is also a good time to be stewing on what cam and heads you want to use That way you can get pistons that will work with which ever heads you are going to use...
