Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rebuild a muncie trans
Old 10-02-2003, 04:41 PM
MI2600's Avatar
MI2600 MI2600 is offline
Member# 3287
Sounds like your synchros and/bearings are worn. Working on the Muncies isn't that hard. I used the GM manual which had the exploded diagrams. The only time I had a problem was with the 100 or so (loose) needle bearings that are between the input shaft and the output shaft. Patience my son!
