Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rebuild a muncie trans
Old 10-02-2003, 07:43 PM
85406 85406 is offline
One thing to look for is when it is jumping out of gear along with the things others have said is if the shift forks are worn it will not be fully in gear and will jump out. Also if the shift collars are worn it does the same thing. When you get it apart check those and let us know.
