Rebuild no power - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2010, 03:14 PM
Rebuild no power
Okay start with basics its a 75 nova with a 327 started it and drove yesrterday.I comeout today and try to crank it and no lights no door buzzer and no engine start. So i though bad battery and replace it with a full charged one. I checked wires they all seem good. I can jump the starter but it sounds like it only spins the starter and dosent push it out to the flywheel? What fuse or what wire could be causing this. Starter is a mini torque gear reduction if this helps
Old 07-11-2010, 01:20 PM
I went outside and tried to softly wiggle the wire block on the fire wall nothing. I looked connections over again and nothing. Would anybody possibly know which fuse i could look for that would control all power. Could this be a ignition switch problem. Also does anybody know a 75 nova fuse panel layout, Any help or suggestions would be great. Also would it be safe to crank it by jumping the starter just to get it in the garage
Old 07-11-2010, 01:33 PM
poncho62's Avatar
Wiki Edits: 5
Sounds to me like you have lost your accessory power.......Look on your firewall, I believe there is a block there which the 10 gauge red wire connects too.......This wire runs from the large positive post on the starter to this block. That wire also has a fusible link in it.....if you have no power at that block, chances are you have blown that fusible link. If you do have power at that block, you have a problem beyond that.....maybe the switch, but usually not.....usually a wire has corroded of.......It is 35 years old.
Old 07-11-2010, 04:34 PM
Thanks poncho, I am going outside and seeign if i can figure it out more. I believe its a lost wire that must have been burnt but now i am knowing where to look. I apprehciate it and will keep u informed
Old 07-11-2010, 06:46 PM
Okay this is what i found power at battert and on starter stud. No power on altenator or fuse board. But i found the positive wire off the satrter had power leaving but lost power halfway thru so i checked after my wires heat shield tube and had no power so i pull those wires out and found a fusible link. I dont know how to check these but this seems to be where the problem is most likey. I wanted to ask yall before i started cutting into wires though
Old 07-11-2010, 07:00 PM
Nova327,
This is the problem. For the sake of speed just cut the fuse-link out and connect the cut ends together and run the system without the link and see if things work again. If they do then buy a new fuse-link and install it where the old one was. BUT if this were my car I would put the link where I could get at it with ease.
Scholman(retired)
Old 07-11-2010, 07:29 PM
Yes Father,
Just kidding but you do sound like pops. I will cut the link out in the morning and install a new wire there and a install a fuse link behind the valve cover! I will let you know if it works. Thanks much
Old 07-11-2010, 11:04 PM
Nova327,
Hey good luck.
Scholman(retired)
Old 07-12-2010, 09:26 AM
Cknarf's Avatar
Pontiac Pilot
I think I'm having the same problem with my Formula, or close too it anyways. I just got it back after a rebuild a few days ago, and the battery seemed to be dead. I switched batteries, and it eventually died. Maybe my alternators toast. After that, I tried boosting it, I got it to start but I had no dash lights, one dim headlight and no taillights. The morning after, I went to boost it and the starter only cranks a small amount. It just wants to melt the cable ends off now...
Old 07-12-2010, 12:05 PM
poncho62's Avatar
Wiki Edits: 5
Sounds to me like you have a major grounding problem.....check all your ground connections
Old 07-12-2010, 01:31 PM
Well it was the fuse link and I installed a new one and it didnt last long. So I check my altenator and it was grounding out on my valve covers. I have converted over to a Gm serpentine belt system on a 327 which left me little room to play off altenator stud and valve cover. I fabricated the valve cover inward which kept it from grounding out. I changed the fuse link to a little fuse tube. Makes changes much easier. I also redid both wires going to starter shouldnt have anymore problems for awhile I hope.
Carb rebuild - won't start now. Please help? joe99 Engine 6 11-30-2011 03:04 PM
Stock rebuild alum. Glide power expectations? ForceFed86 Transmission - Rearend 9 08-25-2009 01:11 PM
power steering won't return to center powerrodsmike Suspension - Brakes - Steering 32 10-12-2006 08:22 AM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
70' chevelle power steering box rebuild kevin2004 Suspension - Brakes - Steering 2 04-30-2004 06:59 PM
