to rebuild or order a short block - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2009, 09:48 PM
my block cracked now to decide to get a crate short block or rebuild another block.
My spare still sits in the 72 chevy pickup it came with. The rings are bad enough it got parked so definitly have to bore. Can't remember the casting number but it is an unopened 350 with a 1 or 2 barrel carb. I think it is a 1 barrel. Carb is the size if my fist. 2 bolt main. I haven't decide about transferring the 327 large journal crank. I need new pistons. the old ones are way too much compression for me(11.5). Getting a new cam either way.
This will be a daily driver with vortec heads around 9.5 c/r. Shooting for around 375hp. Which would be cheaper? I have seen short blocks for under a grand, but not sure if they are worth it.
Old 06-08-2009, 07:56 AM
*** Please post solutions ***
I recommend Blaine's Engines out of Dallas... I am running one of their race engine...
Believe it or not a short block $485.00 Heads set up and ready to go $330.00
Really nice work Call Sean and tell him Fred sent you.
1-800-442-1638
-=Fred=-
Old 06-08-2009, 09:25 AM
kleen56's Avatar
Whether you rebuild or buy a crate motor, you really need to be careful. Crate motors are the easiest way to go and several machine shops will even build the engine they way you want. $1000 for a complete motor sounds like the local auto parts small block offer. I've heard some strange to nightmare stories about those and I'd be cautious on dropping the money for a piece of junk motor. Another option is assemble it yourself and find a great local machine shop that will do all the machining for your. I would ask some local hotrodders in your area.
Old 06-08-2009, 09:40 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Be aware that the label, "rebuilt" or "remanufactured" means different thing to different shops.
If you see a shortblock for <$500.00, does it have used pistons in a honed bore? If not, I don't see how the shop could afford to bore and install fresh pistons/rings, turn the crank, install bearings, etc. and still turn a profit.
You can take a chance on a junkyard engine that's in running condition, hit up craigslist, shop the machine shops in your area for engines that weren't picked up (and price the rebuilding of your old engine while you are there), shop the newspaper classifieds, look for a running vehicle w/a 350 in it for cheap- the options are many and varied.
BTW- A '72 350 truck will have at least a 2-bbl. on it.
Old 06-08-2009, 03:17 PM
Blaine's uses all NEW parts except the block...
All work done on CNC hence the low cost
check out their website!
-=Fred=-
A satisfied Customer
Old 06-08-2009, 05:01 PM
Purchased a GM 350 290 HP crate motor brand new from GM have had nothing but problems (overheating) with it and ran into a gent at the York street rod show having the same problem. The problem we both have is getting answers to questions no tech line available - only e-mails saying never head of that before. I am sure I will work the problem out now that I have found someone else with the same problem.
The point....Cheap does not always work.
Look for local shops and ask for recommendations if there are any
good, they will give them out ,Then call them and ask if the had
problems. After I got the crate motor my local auto parts told
me about a local re builder 1 mile from me $1,000.00 including
heads, all new parts They supplied used block. 40 years in
Business does not advertise other the word of mouth and does
have problems. Boy did I make a mistake....Jim
Old 06-12-2009, 01:12 AM
thanks I will check out Blaine's.
Motown 427 Short Block Build duckbutter69 Engine 3 09-20-2006 03:40 PM
short block, long block astrops Engine 5 04-11-2004 08:14 PM
Meaning of the iron cross? FASTCHEVY Hotrodders' Lounge 15 03-05-2004 11:01 PM
what is the correct or best order for rebuild Zartan Engine 16 02-05-2004 08:52 AM
Looking for a LS7 short block hcheetwood Engine 1 08-18-2002 12:07 PM
