rebuild rear end in garage? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2007, 06:20 PM
It will too fit!!
I have a 79 camaro that has an outer bearing going and I was wondering if I could (or should) rebuild the whole rear while its parked this winter. Is this a doable job for a first timer? Thanks
Old 07-25-2007, 06:50 PM
302 Z28's Avatar
Outer bearing as in axle or carrier bearing? Bearings are fairly easy and straight forward to replace. If you do not have the pullers and a press you will have to have the carrier bearings pressed off and new ones pressed on. Same for the rear pinion bearing.
Vince
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
S-10/Camaro Rear End slaveforthewave Transmission - Rearend 7 02-20-2006 01:44 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 05:32 AM
dodge challenger in need of rear end advice. Journier Transmission - Rearend 0 05-28-2004 10:23 PM
