Rebuild Time? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2005, 08:43 PM
Novaman78's Avatar
Kill It & Grill It
Last journal entry: New door panels
Rebuild Time?
OK this all started about a week ago when it started staying below 20* here so im not sure if it is cold weather or i need my Trans rebuilt. This is a TH-350 and has been in my car since the end of august, i only have about 1,000 miles on it with a new filter. I don't know anything about this transmission except that is supposedly has a shift kit in it. I never did any work to it except a fluid and filter change. When shifting from 2nd to 3rd the trans slips a little then goes to 3rd ( not all the time just when getting after it harder than normal driving). 1st to 2nd shifts have always kind of hesitated the it was a quick hard shift and it still does this and also slips going into 3rd. Today i put a new pan on my trans and the old pan had a few clumps of very fine aluminum shavings. I scraped it all together in the bottom of the pan and it was a little bigger than the size of a quarter. The fluid doesn't look or smell burnt. Is this anything to worry about?
Old 01-19-2005, 10:28 PM
willys36@aol.com's Avatar
Wiki Edits: 21
You bet your bippy there is something to worry about! Metal shavings of any kind in a tranny is an indication of pending disaster. Don't drive it again until you find and fix the problem.
And I can't imagine -20F!!!!! Have only seen +20F a few times in my life. Aren't all the fluids in your car solids at that temp!?!?!?
Old 01-20-2005, 06:48 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
fine metal particals are normal in a t-350 with miles on them......although in a few miles as you post I would wonder why so much so soon.
sounds like the tranny needs to come apart to diagnose the problem you are having with 3rd gear
Old 01-21-2005, 12:41 PM
Novaman78's Avatar
Kill It & Grill It
Willys its not -20* i meant its been staying below +20*. I don't know how many miles are on the transmission for sure but i have only put about 1000 on it. Yesterday i was driving to work and found if i had my foot about half way down it would slip. If i let off or gave it more gas it would shift. If i had it 3/4 of the way down it shifts fine, same way if im just driving. It only does this at about half throttle. Could this possibly be my torque converter? A mechanic around here said it probably is. He said it makes sense for it to be the converter if i give it more gas or if i let off and i shifts. What do you guys think?
Old 01-21-2005, 07:03 PM
tbirdscott's Avatar
stuff'n things'n whatnot
Originally posted by Novaman78
If i had my foot about half way down it would slip. If i let off or gave it more gas it would shift. If i had it 3/4 of the way down it shifts fine, same way if im just driving.
My car does the same thing shifting from 1-2 sometimes, and i'm pretty sure it's almost dead (1980 c4 w/200 000km) You say that you have only put 1000 miles on it but any idea how many were on it before you added that 1000? if you bought it used I wouldnt hold much hope for it, atleast TH-350's are easy to find!
Old 01-21-2005, 07:57 PM
Novaman78's Avatar
Kill It & Grill It
yes. WEll it looks like im giong to be looking for a trans.
Is this a good kit to get? It also has a shift kit too right? Everything i need in one kit?
