Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rebuild vs Crate???
  #20 (permalink)
Old 03-12-2012, 06:00 PM
starnest's Avatar
starnest starnest is offline
elkyholic
Last journal entry: Center Link Installed
OK - you've got 70 307 heads (small valve, 69CC) on a 67 327 block. It'll work fine for just cruising around. If everything checks out, I would replace the flex plate and put it in the car. If you have problems after that, you could rebuild it and with a few improvements make a hot little 327 with the right heads and cam.
