rebuild a walker 2 ton floor jack - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2010, 10:49 AM
who rebuild them or how and where do I get the O rings etc
Old 09-17-2010, 01:18 PM
deadbodyman's Avatar
Wiki Edits: 11
www.Grainger.com
Old 09-24-2010, 09:00 PM
Walker jacks have changed ownership and name about 4 times over the last 20 years. Currently they're sold under the Hein-Warner name. You might contact them to see if they still supply repair kits for the Walker jacks. There are some seals in those jacks that you WILL NOT find in any sort of regular industrial supply house.
Another option is to take the jack apart and take the seal parts to a hydraulic seal shop if there's one in your area.
If there's no one local, you could likely match the parts up online at http://www.herculeshydraulics.com
Based on work I've seen in the past, I'd have to have some good recommendations from prior customers before I'd take a jack to the typical hydraulic jack repair shop. I own a machine shop and do some hydraulic repair work, and the worst messes I've ever worked on were ones where some jack repair yokel had "fixed it'. I've seen pieces of PVC pipe used in place of plastic piston bearings, cut up wheel cylinder cups used where a U-cup seal should've been, and more other examples like that than I've got time to list. Not saying they're all bad, but I'd want a reference from someone who'd had work done that has held up for at least several months before I'd turn one of 'em loose on anything of mine.
Old 09-14-2012, 07:25 PM
rebuild walker jack
Very few places want to rebuild floor jacks, I am told there was no money in it. I have a walker model 770a that I have been trying to find parts since 2009.
i am told there is not much to them, however you luck could be better than mine
Ohio Hydralics
Mac Guyre
Carb rebuild - won't start now. Please help? joe99 Engine 6 11-30-2011 03:04 PM
stroker 383 or 350 rebuild rbat Engine 34 12-10-2009 02:19 PM
Question on Edelbrock carburetor rebuild kits. eric32 Hotrodding Basics 8 05-18-2009 05:19 PM
Starting a rebuild, Serious Question. Funeral Hotrodding Basics 1 10-12-2008 12:35 AM
T-350 Rebuild DIY - First Time V8 Super Beetle Transmission - Rearend 8 06-26-2008 09:14 AM
