rebuilding 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2003, 06:32 PM
Post rebuilding 350
Would it be the best to take the block to a michine shop to put a cam in or put it your self Which will be the fastest and will you have to change the cam bearing going from factory to 420 lift and 214 duration how hard is to change them if so. And do you have to line bore it to make shure it straight.
Old 02-21-2003, 09:21 PM
BOBCRMAN@aol.com's Avatar
Post
you do not need to change cam bearings unless they are worn or gouged up from sloppy cam installation, takes a special tool,complete disassembly of engine. you only need line bore if the crank turns hard in the bearings or the housing has mismatched caps or spun bearings or out of round bores.
Old 02-21-2003, 11:07 PM
Croz's Avatar
Hotrodders.com moderator
Post
in this case, i would say a machine shop.
Old 02-22-2003, 05:51 AM
slider in wa's Avatar
Slider in Wa.
Post
Have you ever changed a Cam before? I think Croz it right and has given you good advice.
2 penny`s worth.
Slider in Wa.
Old 02-22-2003, 08:27 AM
Post
Yes I'v changed cams in many big blocks but just a few small blocks I Put a factory corvette cam in and 350 with out taking to a shop and it was soild lifers and it's run's good and hit's hard still today.
