Rebuilding 400sbc need feedback - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2010, 08:02 PM
400sbc +.30= 406ci
bottom end balanced,
this is what i want...
64cc Vortec heads with .600lift
Lunati Flat Tappet Hy Cam 504/525 lift
Performer RPM Vortec intake
800cfm thunder series carb
1:6 ratio full rocker rollers
or
TRICK FLOW TOP END KIT (FOLLOW LINK PLEASE)
http://www.summitracing.com/parts/TFS-K314-490-440/
ALSO I WANT TO REMOVE THE AC AND ADD A V-BELT, AND I NEED HELPING PICK OUT A STALL CONVERTER.... EVERYTHING HELPS, THANKS IN ADVANCE
Old 05-29-2010, 09:11 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
It will be hard for the vortec heads to come close to those aluminum trick flow heads. I guess depends wether you are after saving money or making power. The vortec heads will be cheaper but the the trickflow top end will make more power. Also depending wether you get a custom converter made or buy one from like hughes or tci you need to look cam timing figures.
Old 05-31-2010, 06:14 AM
The trick flow kit is the way I would go over the Vortec set up. The stock Vortec head is a little small on a 400 sbc for performance use.
Old 05-31-2010, 06:32 AM
Show me the money !
You probably already know this but If you use that trick flow kit, You will need to plan on getting those heads drilled for steam holes. Just putting in my 2%
Old 05-31-2010, 11:25 AM
406cu.in. of tire smokin' fun
Last journal entry: 406 Build Thread
I just finished building a street 406 two months ago. It has vortec heads and I'm pretty happy with it. I can see how it might run out of steam at higher RPMs, but it wasn't worth the extra coin for new heads. I compared stock vortecs to the AFR heads on a dyno program and the projected gains weren't worth 2K for me since I am not going to race it. It's definitely fun to drive though.
Old 05-31-2010, 12:33 PM
Listen and Learn
Wiki Edits: 7
So will the vortec heads
Old 05-31-2010, 02:19 PM
Originally Posted by 86_Z28
400sbc +.30= 406ci
or
Are you still using the stock 400 crank and 5.56 rods? If so, that's a lot of money to invest on a top-half...when you're running a stock bottom-end.
Rebuilding Quincy 325 Compressor Joelk Garage - Tools 17 10-17-2010 06:37 AM
305 engine rebuilding Cerry Hotrodding Basics 26 01-06-2009 01:04 PM
colors for Youngrodders.com, looking for feedback Jon Hot Rod Art 29 04-20-2007 11:44 PM
Short ebay feedback rant killerformula Off-Topic 48 01-17-2007 06:32 PM
Rebuilding Chevy Van steering column Sly's 53 Suburban Suspension - Brakes - Steering 5 02-14-2005 07:43 AM
