Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rebuilding a 54 front end?
Old 04-23-2002, 07:43 PM
WoodsEdge's Avatar
WoodsEdge WoodsEdge is offline
The easiest way I've found is to go to a Mustang II front suspention. Don't know how stock you want to keep it. I'm building a 50 Chevy panel truck but its going to be a hot rod. I used a Fat Man crossmember and stock Mustang II a-arms and springs with 82 Caprice 11" roters. I'm also using the Caprice rearend with Posie's springs. I also went with a power rack and power brake master cyl. Brent at Fat Mans will be glad to answer any questions you have. This is a fairly simple swap if you can weld and fabricate. Hope this helps, Jack
