Rebuilding a '64 chevy (car) rear end - help - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2005, 07:44 PM
New to this and would like to know if anyone has a tech sheet, diagram of the rear end disassembled? Or, how to go about doing this?
Old 04-21-2005, 06:52 PM
willys36@aol.com's Avatar
Wiki Edits: 21
This is a great opportunity for you to learn how to use the search feature of the board. Do a search and you will find everything you need to know - this topic has been covered in depth many times.
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 10:03 AM
Rear End Axle Code for the Chevy S -10's Traps Restoration Transmission - Rearend 1 02-27-2005 11:05 PM
Rear end identification help 71gtx Transmission - Rearend 1 11-07-2003 08:14 PM
57 Chevy rear end Mrfixmaster Transmission - Rearend 6 03-11-2003 12:12 PM
Chevy rear end wobbles. whoohaadan General Rodding Tech 3 03-04-2003 10:03 AM
