Rebuilding a 700R4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2007, 07:01 PM
Rebuilding a 700R4
Hi All, This my first post... so be gentle. I am replacing the TH350 in my '69 Camaro with a 700R4. My question is regarding the 1-2 and 3-4 accumulator springs, I took them out and didn't mark which went where, there are two different size springs, a heavy black one and a lighter green one. Can someone help me out with which goes with the 1-2 piston and which with the 3-4. Thanx in advance... Hugger
Old 06-12-2007, 08:15 PM
302 Z28's Avatar
Crosley will chime in here in a bit and can answer the question, but in the interim, why not just order a shift kit from Transgo, it will come with new springs, TV improvement parts and good diagrams. The kit is the SK700jr and it runs about $30 and will improve the 700R4 performance considerably.
Vince
Old 06-12-2007, 08:59 PM
Crosley's Avatar
Wiki Edits: 1659
the lighter duty spring is used on the 3-4 accumulator piston (in the main case)
Putting a 1987 700R4 in my 1982 GMC 4x4... indy_85stariones Transmission - Rearend 12 04-28-2007 02:04 PM
Rebuilding a 700R4 in 4x4 for towing... indy_85stariones Transmission - Rearend 4 02-02-2007 01:26 PM
rebuilding a 700r4 trans Ace_Spades307 Garage - Tools 1 11-27-2005 09:44 AM
700r4 rebuilding questions Anton Transmission - Rearend 1 06-07-2005 09:41 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
