Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rebuilding a 700R4
Old 06-12-2007, 08:59 PM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
Originally Posted by hugger
Hi All, This my first post... so be gentle. I am replacing the TH350 in my '69 Camaro with a 700R4. My question is regarding the 1-2 and 3-4 accumulator springs, I took them out and didn't mark which went where, there are two different size springs, a heavy black one and a lighter green one. Can someone help me out with which goes with the 1-2 piston and which with the 3-4. Thanx in advance... Hugger
the lighter duty spring is used on the 3-4 accumulator piston (in the main case)
