rebuilding a 700r4 trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2005, 08:22 AM
Ace_Spades307's Avatar
FAB/MASTER WELDER
I'm rebuilding a 700r4 never done it before is there any special tools I need to rent or buy besides wrenches or sockets or even calipers for measureing the gaps
Old 11-27-2005, 09:44 AM
topfuel's Avatar
ASE Certified Master Machinist
Last journal entry: More Pics
Yes there is Ace. You will need tools for installing and sizing the turbine shaft sealing rings as well as the stator shaft sealing rings as they are solid. There are seal tools for installing the clutch pistons and you will need a special spring compressor to remove and reinstall the clutch pistons. A nice assortment of snap ring pliers and an inch pound torque wrench along with a good dial indicator and feeler gauges will be needed. I hope this helps.
700r4 rebuilding questions Anton Transmission - Rearend 1 06-07-2005 09:41 PM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 11:14 AM
700R4 trans conversion to 70' C10 2WD steve d Transmission - Rearend 5 01-31-2004 01:56 AM
700R4 trans woes derone Transmission - Rearend 3 10-23-2003 08:58 AM
700R4 Trans for my 36 Pontiac Hearse? Big_Indn Transmission - Rearend 3 08-18-2003 11:30 AM
