Rebuilding an 8" Ford RE - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2005, 12:46 PM
My search didn't come up with anything so, how hard is it for a novice RE builder to redo a Ford 8"? I plan to pull the 3rd member, replace the 3:00 gears with 3.73, using an installation kit and hopefully installing an affordable posi, like an Auburn cone? Instructions come with the kit? Any hints or heads up B4 I start?
Old 07-07-2005, 12:59 PM
Just moving this up the list as I can't believe no one here has redone a Ford 3rd member! 9" should be the same drill as an 8".
Old 07-07-2005, 01:29 PM
aka Duke of URL
-FROM THIS SITE'S KNOWLEDGE BASE-
Old 07-07-2005, 04:19 PM
Just so you get some sort of reply, I thought about doing mine seeing as how I do everything else on my car, but backed out at the last minute and had a friend that is a mech. do it. after that I think I could have done just as well. I backed out because I couldnt get any good info about the process. if I had it to do again I would do it. it seems pretty simple. about the hardest part was getting the pumpkin out. it was because the stock copper crush washers wee still on it and was holding tight. so watch out for those. once they were off it fell out real nice. let me know if you have any specific ?'s about anything and I will try to help. I did the same swap 3.00 - 3.73 only I put in a powertrax lockright locker. good luck
Old 07-07-2005, 05:41 PM
lluciano77's Avatar
It is easy to do. The hardest part is setting up new gears if you put them in. You have to get the gears to mesh correctly.
The ring bolts will be hard to break loose at first.
Old 07-08-2005, 07:44 PM
Thanks a bunch guys! I now some confidence & info in moving foreward. I kind of like to do things myself as well, so I'll do it SLOWLY & carefully & then rip off some better starts!
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
Selling a mid 60s, early 70s Ford 8" bildo95 Transmission - Rearend 2 08-19-2002 12:12 PM
8" Ford Rear info.Wanted. Barry.M Transmission - Rearend 10 08-16-2002 02:14 AM
Enhance a Ford 8" or ?? Strick Transmission - Rearend 13 07-18-2002 06:16 AM
