a big bore kit, pipe and rejetted carb, a NOS kit for a Mikuni carb flange if your crazy.
i'm kinda leary of useing NOS, but the others sound pretty sound, it has a Cobra exhaust on it now, is that a good system? as you can tell i'm new to Motor cycles and ATV's in general
just a FYI this is the transmission/rearend section.
Mill the head down a little, take a dremel tool and clean up the ports a little, do a port-matching job for the manifolds, but I wouldn't try actual porting without good knowledge of how it all works with velocity, flow, etc. |
sorry about posting in the wrong section, i have a friend that knows how to port one of these small motors, how much do you suggest, rough estimate shaveing off of the head? like a few thousandths or so at a time?
I'm not sure... I don't know exactly the min. safe valve/piston clearance (shaving head brings valves closer to piston, they hit and you have scrap metal), I think 0.050 inch... not sure. I'd ask someone experienced with the engine in question. |
was that with the stuff that was listed before?
that's pretty impressave man 110HP i'd be happy to just get a measly 50 or 60 out of this engine, he must have a blast with his Mini-Rod, and with the clearanceing, would getting the piston TDC and measureing the distance with like a feeler gauge or something like that work... i'll just call a friend of mine, he sent his top end to a machene shop to have it ported, polished, and clearanced O.O, i think he had a set of valvs put in, i'm not 100% on that though, i'll find out what shop he used, and see how much they want to do a thing like that on that head
| crate chevy 302? | Vancouver Grand Prix | Hotrodders' Lounge | 106 | 12-31-2012 04:05 PM |
| the history of chevy v8's | savman1 | Hotrodders' Lounge | 43 | 03-02-2012 06:57 PM |
| Valve Lash adjustment | hiball | Engine | 36 | 05-11-2009 10:12 AM |
| 1969 350 375HP GM Goodwrench Replacement Engine | Big Daddy Teez | Engine | 2 | 03-21-2006 07:36 AM |
| rebuilding specs for olds engine | Blob | Engine | 2 | 11-30-2004 08:03 PM |
