rebuilding a borg warner t-10 in a 2.8Ls10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2006, 11:02 AM
Hello I was wondering how hard it is to rebuild a borg warner t-10 5 speed in an s-10 2.8L motor.....mine is starting to make a whining noise and in the summer time when warm at a stop sign foot off the clutch pedal and in neutral it will make a growling noise, push the pedal and it will go away. when I built the truck I changed it from automatic back to the 5 speed so I threw in a new clutch and throw out bearing. rear end is also been replaced
Old 02-17-2006, 11:03 AM
Sorry that was t-5 not a t-10
Old 02-17-2006, 11:12 AM
rsafreed's Avatar
T-10?
Sounds like maybe a input shaft bearing in the trans
F-body differentials, 9 bolt Borg Warner vs. GM 10 bolt Mad Maggot Transmission - Rearend 8 02-17-2005 09:02 PM
borg warner t5 classic_chevy_guy Transmission - Rearend 2 09-05-2004 08:45 PM
Replacing Borg Warner T10 with Richmond 6 speed beazil Transmission - Rearend 3 05-16-2003 09:59 AM
Borg Warner scott011422 Transmission - Rearend 0 04-28-2003 03:53 AM
Borg Warner T-10 fred56 Transmission - Rearend 2 11-02-2002 07:02 PM
