Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rebuilding found 68' GTO Timing Problems
Old 08-06-2012, 03:53 AM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
Your car, your money....... but I'd stop throwing parts at it untill I found what was wrong with it. Now don't get me wrong if a parts bad... replace it, and after you get it running correctly replace all you want...... Reason being... you've not corrected the original problem but have added several areas to the possible list of what it might be....yadda-yadda....
Sounds like you got a firing order, dizzy alignment issue.
