how would i go about aligning the distributor if it only drops in in 2 spots in the oil pump shaft. Meaning the flathead screw like rod that fits in the notch in the bottom of the distributor only drops the distributor in in 2 positions. How do i rotate the distributor gear until it is perfectly alligned ie one tooth at a time, if the dizzy will only drop in those two spots. Our problems seems to be that the oil pump shaft wont allow us to drop the dizzy pointing towards the #1 plug.
Reason: bad wording
