Sounds like a basic stock rebuild will do. 250 hp is pretty much stock. Tear the engine completely down, take it to the machine shop and have them look over everything. They'll tell you what needs to be replaced, machined, etc.
A good upgrade would be to go with a retro-fit roller camshaft for reliability. |
It might be a 305, rather than a 350. Post the casting number on the back of the block where the bellhousing bolts up, driver's side. (Can be seen from the top).
My casting no is 10054727
Made in Canada. The RPO should be L05. Please correct me if I am wrong. Need a complete overhaul gasket set, rod bearing, main bearings, camshaft bearings, rings. Is is already a center of bolt valve cover! Who has the best quality and great prices. Ebay? BR |
86 & up, 2 or 4 bolt, 1 piece rear main seal. I'm guessing you already know that by now.
Summit has some quality / affordable rebuild kits. They come with or without pistons. http://www.summitracing.com/search/P...ebuild+kit+350 They also make some camshaft kits with lifters. http://www.summitracing.com/search/P...ummit+camshaft I have a few Summit house brand parts (carb, RPM intake, lifters, water pump, pulleys...) and they've worked well. You'll need to know piston and bearing size for the rebuild kit. Did you plan to have a machine shop check out what you have? I would at least have the crank ground .010 undersize and possibly have the bores enlarged .030 over, assuming it's a virgin block, just to clean things up. |
| GM Target Master 350 | CamaroZ28 | Engine | 1 | 10-06-2009 04:06 PM |
| 350 SBC Build Help | Doc Hawk | Engine | 6 | 08-13-2009 08:25 PM |
| 350 V8 Chicking and Clanking | JustinBailey | Engine | 8 | 04-22-2009 05:53 PM |
| 350 sbc crate motor questions | bentwings | Engine | 7 | 10-29-2002 08:03 PM |
| 350 GM Goodwrench Caprice engine in 3rd Gen TBI F-Body? | wrmason3 | Engine | 2 | 09-14-2002 07:01 PM |
