Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rebuilding my first holley 3310
Old 10-03-2012, 02:08 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
If the bib block hat a hot cam then the power valve should be closer to stock for your application.note jet sizes and go up or down 2 sizes at a time.If you are lucky then the carb may have been modified to have change able air bleeds,note their sizes too if they are remove able. a standard 30 ss pump is all you will likely need and the cam position is adjustable so I wouldnt change it yet. check pump discharge nozzle size while the carb is apart
