Rebuilding my Rear Drum brakes from bare backing plates!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2006, 02:09 PM
chevymastermind's Avatar
drive it like you stole it!
Last journal entry: engine
does anybody know of any site that would assist me in the rebuilding of my 72 Novas rear drum brakes. i already have all brand new hardware and parts and bare backing plates! i need to know how to put all the parts on! Help!!!!!!!!!!!!!!
Old 10-30-2006, 02:44 PM
rj57's Avatar
Usually in these type of situations what I do is remove both brake drums but only tear down one side at a time.
This way I have the other side as a reference "Just incase."
Old 10-30-2006, 03:53 PM
poncho62's Avatar
Wiki Edits: 5
Here is a simplified drawing to start..
You can also check here for other diagrams.
http://www.carbibles.com/brake_bible.html
Old 11-01-2006, 10:23 PM
The short shoe goes to the front.
You should be able to pick up a Haynes or Chiltons manual up at your local autoparts house. In it you'll find the necesarry instructions to put your brakes back together.
Topher
Old 11-03-2006, 08:58 PM
jray's Avatar
I've been doing brakes since I was a teenager many.many years ago and I still do it this way.....
Old 11-04-2006, 05:40 PM
MI2600's Avatar
Member# 3287
I agree with doing only one side at a time...but it presumes that the idiot who did the brakes the last time knew what he was doing. I found that out the hard way.
Old 11-15-2006, 12:29 PM
I do them one side at a time as well, but the cautionary statement above is correct. On my most recent acquisition, a 67 mustang, whoever did the brake job last left a couple of parts off. I only knew this from experience. So if you don't have any, best to get a manual.
Good luck.
Old 11-15-2006, 07:58 PM
Last journal entry: Sweet Looking Dash
Chilton used to make a $15 paperback book for the 68-74ish Nova's. I know I had one in the garage in the 80's when we ran these as oval track car's. If your doing alot of work on the car, you may want to see if Chilton still makes these. The book will basically show you everything you need to know to work on the engine, tranny, front suspension and rear suspension on these nova's.
Godd Luck and have fun, these Nova's are very good cars
Clark
rear end / brakes, etc / INFO?? Pickup Guy Hotrodding Basics 7 08-02-2007 02:06 PM
Locking drum brakes burninrubbah617 Suspension - Brakes - Steering 1 01-15-2006 03:09 PM
Can a guy use a disc/disc master with drum rear? MM in NM Suspension - Brakes - Steering 1 12-08-2005 06:08 PM
Brakes yogo2121 Hotrodding Basics 7 12-06-2005 08:02 AM
Rebuilding drum brakes. 69ChevelleAddict Suspension - Brakes - Steering 6 07-06-2005 07:13 PM
