Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rebuilding Power Washer Wand
Old 09-10-2010, 08:57 AM
35WINDOW's Avatar
35WINDOW 35WINDOW is offline
Last journal entry: Update on my Build-Lights
What you are describing in terms of the "seal thing" is probably a back-up washer-it stabilizes the o-ring so that it can't deform out of the o-ring groove. I believe the reason you can't shut off the flow is that the o-rings are deforming and won't allow the valve to return to home-
Go to a Hydraulic Repair shop or a Construction or Agricultural Dealer-they are a common item in those Industries-
