Rebuilding Power Washer Wand - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2010, 07:13 AM
I have an Excel Pressure washer with a 5hp Honda engine on it and a junk oil less pump. I ordered a much better oiled pump with a thermo relief valve so that should take care of the pump issue. The other issue I have with it is water leaks out of the wand handle where the trigger is. I can buy a new wand for $40 but I would rather just fix mine. I took it apart and right away found where the leak was.
There is a brass collar and a brass fitting that goes into the collar. The fitting slides in the collar turning on and off the water. There is an o-ring and a brown looking seal thing (not really sure what it is exactly) that go into the same groove (side by side) on the fitting. Both o-ring and seal thing are very worn on one side. I was thinking of just replacing both with two o-rings. Do you think this will work?
My last question is what should I use to lubricate the seals? I was thinking of using high temp axle grease but wondered if there was something better?
Thanks
Old 09-09-2010, 07:38 PM
russlaferrera
Last wiki edit: Threading tips
Wiki Edits: 2
It is worth a try. They do make a High temp grease for steam valves that is available at a plumbing supply
Old 09-09-2010, 08:31 PM
SuthnCustoms's Avatar
Crazy Ole Ironhead
I've replaced those O-rings in pressure washers that people sold for practictly nothing because they leaked and lost pressure and resold for a hefty price,about 10.00 at the most at the local auto store for a bag of different sized O-rings and the things work like new.
Old 09-10-2010, 07:35 AM
thanks guys, I gave it a try and the wand is sealed right up. The only problem I have now is that the wand will not shut off completely. There is always a slow stream of water coming through the tip. Any ideas on how to get this stopped?
Old 09-10-2010, 08:57 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
What you are describing in terms of the "seal thing" is probably a back-up washer-it stabilizes the o-ring so that it can't deform out of the o-ring groove. I believe the reason you can't shut off the flow is that the o-rings are deforming and won't allow the valve to return to home-
Go to a Hydraulic Repair shop or a Construction or Agricultural Dealer-they are a common item in those Industries-
Old 09-10-2010, 09:06 AM
Thanks, I will look into that. Nice to know what the washer thing really is.
Dropped 5/16" SS Washer in Intake Manifold beam6325 Engine 11 08-17-2010 10:15 AM
Suggestions for the "Best Method" to add power to a given application. roach4047 Engine 4 08-01-2010 06:12 PM
rebuilding porta power 10Tonhammer Garage - Tools 1 03-28-2007 12:46 PM
degreaser for power washer? cboy Garage - Tools 6 11-19-2006 03:00 PM
'97 Sable electrical & washer pump problems Gearhead forever Electrical 9 12-03-2005 05:31 PM
