rebuilding a saginaw - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2006, 01:06 AM
is a 3 ring saginaw worth putting new gears in i tore out first and can't find another one i heard if i just put one new gear in it it would go out because of uneven wear and how much is new gears and rebuild kit and someone to do ti
Old 07-04-2006, 11:45 PM
Did only first gear get trashed, or did the corresponding section of the cluster gear get eaten, too? If only one is obviously broken, you need to check the other closely to make sure it's truly undamaged. If it's OK, you can replace the one gear, but it may be a little noisy. Low gear is usually a bit noisy anyway, so I wouldn't be too worried about it.
A transmission place is liable to stick you for a pretty good labor charge, but if you're adventurous and have access to a good lock ring tool, you can probably do it yourself. It's a bit intimidating, but if you take it apart carefully, keeping everything in order, and noting which way everything faces, you should be fine.
http://www.dandltransmission.com/saginaw.html has rebuild kits and may be able to supply used gears if available. They also have ID info. Their kits may also include diagrams, but I don't know for sure.
Rebuilding Chevy Van steering column Sly's 53 Suburban Suspension - Brakes - Steering 5 02-14-2005 08:43 AM
Need some advice on a saginaw tran's bowtieorbust Transmission - Rearend 1 10-24-2004 01:59 PM
TH350 vs Saginaw 3 speed ? bowtieorbust Transmission - Rearend 4 01-20-2004 08:16 PM
saginaw 3-speed ? bowtieorbust Transmission - Rearend 2 01-12-2004 09:54 PM
Swapping A 3 Spd 72 Gm Saginaw From A P/u To 4 Spd Saginaw From A 68 Camaro GMC72NV Transmission - Rearend 0 11-10-2003 03:51 PM
