rebuilding steering column.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2011, 10:50 PM
Is there a place close to Barstow, Cal. that rebuilds steering columns? I need one done for a late 60's chevy truck w/ ign. on the dash. Thanks. Even something a little farther is fine.
Old 01-30-2011, 02:38 PM
Steering Colum Rebuild
There are quite a few steering column re-builders, unfortunately I think most are in the upper mid west. I also know that there have been articles written in the car magazines about rebuilding a steering column. Since yours is not a tilt and does not have the ignition in the column it would seem to be a fairly straight forward project. I just went online and searched for steering column rebuild. I think you will find what you are looking for. You may get lucky and find one close to you.
Good luck,
Bill
steering column krangar Suspension - Brakes - Steering 10 05-19-2011 07:52 PM
Rebuilding a GMC Steering Gear Box jdotson7 Suspension - Brakes - Steering 0 05-01-2010 06:41 PM
Rebuilding '72 Nove steering column? Arley Suspension - Brakes - Steering 1 06-07-2007 03:42 PM
rebuilding steering box? 60 chevy Suspension - Brakes - Steering 1 01-04-2006 08:29 PM
Rebuilding Chevy Van steering column Sly's 53 Suburban Suspension - Brakes - Steering 5 02-14-2005 07:43 AM
