rebuilding a th350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2011, 08:09 AM
rebuilding a th350
I am now putting the springs back on the oil pump it says to leave off every third one. Is that correct?
Old 03-20-2011, 08:16 AM
yes some kits say to do that it will give less apply resisstance to the intermediate clutches. same for the direct clutches also.
Old 03-20-2011, 11:42 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Here is how GM located the springs when they were captured on the retainer:
Various locations will work fine. Just do not remove too many springs. Clutch release speed is as important as apply speed
Rebuilding My T-350 Tyler007 Transmission - Rearend 4 08-06-2010 11:17 AM
Rebuilding a T-350. Finding parts? fast68 Transmission - Rearend 12 12-06-2006 05:19 PM
Rebuilding TH350? Marcus Transmission - Rearend 2 06-01-2004 01:58 PM
Rebuilding a T-350. Is it hard? Maverick Transmission - Rearend 30 10-06-2003 02:17 PM
rebuilding a TH350 limey Transmission - Rearend 3 02-20-2003 07:17 AM
