Rebuilding top end - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-02-2012, 04:47 PM
Rebuilding top end
Leaking intake manifold gaskets on these cars are common. Just replace the intake manifold gasket and flush the radiator and block. Do not use Dex-Cool antifreeze anymore. It is a fact that the Dex-Cool reacts with the material the intake gaskets are made with. Check out this website full of compliants. 2002 Chevrolet Impala Leaking Coolant, Intake Manifold Gasket Failure | CarComplaints.com
  #17 (permalink)
Old 11-02-2012, 06:34 PM
Check your spark plug gaps
I don't want to tear into the engine and replace gaskets that are fine
  #18 (permalink)
Old 11-02-2012, 08:55 PM
Rebuilding top end
The intake gaskets are most likely bad if you are losing antifreeze and cannot find it. Antifreeze is probably leaking into an exhaust port, heating up and evaporating. Is it easy to take the exhaust manifold lose from the heads?
  #19 (permalink)
Old 11-02-2012, 09:59 PM
Okay, I guess I'll replace then even though there is no evidence at all that they are bad since the shop found the problem.
  #20 (permalink)
Old 11-19-2012, 07:53 PM
Snapped this photo on the way to work today
mid 70's bottem end, 1990 top end, 90 water pump...overheating!!! erickmi Engine 4 01-24-2010 07:51 AM
Great Low-end but poor Top end juiced66malibu Engine 10 09-11-2005 10:17 PM
rebuilding a T-Top camaro JH30906 General Rodding Tech 0 04-19-2003 07:54 AM
rebuilding rear end? tonylsg Engine 2 02-17-2003 10:52 AM
rebuilding a 54 front end? Conner Suspension - Brakes - Steering 10 04-29-2002 06:54 AM
