yes, they are not lie'n to you..
the lower end with 300k on it, will now have like new top end, and will suck oil right passed the rings , the rings may not break.. but it won't matter.. it's smoke like a bas__rd.. |
Your machinest is full of S....T.
That is a lot of miles. But those engines are not hard on rings or valve train parts. Aside from pressure testing and milling the heads, HAS TO BE DONE.. A valve job/seal replace will help excessive oil usage. As long as coolant is kept out of the oiling system. I've seen the short blocks on these go many many miles. It's the intake/head gasket problems that kill these engines. Or in this area of the country the trans goes or the engine cradle rots out. |
Before tearing the heads off a leakdown test would give an idea as to how good the rings are assuming the valves hold pressure. Too a general extent what you mechanic is saying is that when the top end is restored to an old engine with worn pistons, rings and cylinder walls that often the result of restored pumping actions above the piston will pull oil around the worn parts and will allow more blow by into the crankcase. This depends upon the wear on those parts. If the engine isn't an oil burner today chances are good you can do the top end without introdcing any new problems. If it passes a leakdown test I don't think I'd do anything but chase and repair the coolant leak. Today's engine valves have special treatments on them that refacing the seats take off, once removed their life span will be shortened and you'll be back into the engine again and again for repairs or replacements. So I'd be cautious about just fixing things that don't necessarily need fixing because we used to do these things as a matter of course a few years ago, much has changed in recent times. Bogie |
I just changed my oil Sunday and let the oil sit in the drain pan overnight and didn't see any antifreeze/water in the pan. Can someone explain to me or give me a link of how to do a leak down test on the cooling system?
I've heard this old wives tale for years. even had a shop owner ask me not to do "too" good of a job on a head rebuild citing that very reason.
i have not yet seen any evidence of it being true. if you think about it, i can understand where that's coming from, but again, I've never seen any proof. |
Bogie |
to me it sounded like the lower end was already bad. i think the op was referring to the top end rebuild causing the lower end to have problems. or maybe i just misunderstood your post. |
Anyways, the engine runs great just have to keep adding coolant and not really sure where its going. I read somewhere about putting a balloon or rubber glove on the filler hole of the radiator and cranking the engine over and if the balloon blows up then you have combustion pressure going into the cooling system. This sounds kinda froggy, need citation? Bogie, could explain how to do the test you were talking about earlier?
The 3.8 engine was a GM wonder. They toyed with this motor, changed things for many years. Untill it started lasting too long. Then it was discontinued.
As stated they last many miles. Most are just getting broken in at two hundred thousand.. Most never see more than 3200 rpm. Cruise at under 2000 rpm. The only problems they have is intake plenums/gaskets and head gaskets. Usually at higher miles. This example probably spent a lot of time on I-75 and I-94 racking up the three hundred thou miles in comfort. These are not 56 Chevrolet engines. They don't have fancy coatings on the valvetrain. It is just GM got it right, finally. Thin rings that don't beat up the ring lands, conform to the cylinders better. Light weight valves and springs. Positive oil controll seals. Fuel injection and OD tranny. You will usually find the leak is on the back head. Drivers end. Between the coolant passage and the fire ring of the last cylinder. It Brinnells into the casting from heat cycling. Usually only leaks, into cylinder, at running temp at higher speeds. You can have any auto repair place put a tester on the cooling system. You may be able to rent/borrow a tester from a chain auto store. Last edited by BOBCRMAN@aol.com; 11-01-2012 at 08:37 PM. |
Yes, the majority of miles were put on the car on the highway cruising at seventy five-eighty with the cruise set most of the time. Maybe I'll just pull into a shop and let them diagnose it. Even if they charge me an hour labor it could be worth it over chasing and hoping.
Bogie |
Thats not a hard engine to find get a runner from the junk yard and go. Forget rebuilding it. Not even the dealer wants to rebuild them. Just replace the lump. My local junk yard has ok shop and will install his engines and gurantee the engine for good amount of miles. Not a bad deal if your stuck. At 300k it will cost a crap load of machine work to get right you could get a good runner alot cheaper. Even if you want a new or performance rebuild dont start with the 300 k engine it cost more than a junk yard motor with 100 k on it and only needing bore and simple machine work to be road worthy. Your curent motor is toast. It will need everything once you take it apart.
The engines not toast, it runs great, never have to add oil. The car has been really good to me. I took the car to a shop and he ended up tracking it down to some thermostat bypass elbow or something like that. So no internal leaks! Two bills later and a huge sigh of relief and I'll be back on the road with my trusty car, wouldn't trade it for a brand new one!
| mid 70's bottem end, 1990 top end, 90 water pump...overheating!!! | erickmi | Engine | 4 | 01-24-2010 07:51 AM |
| Great Low-end but poor Top end | juiced66malibu | Engine | 10 | 09-11-2005 10:17 PM |
| rebuilding a T-Top camaro | JH30906 | General Rodding Tech | 0 | 04-19-2003 07:54 AM |
| rebuilding rear end? | tonylsg | Engine | 2 | 02-17-2003 10:52 AM |
| rebuilding a 54 front end? | Conner | Suspension - Brakes - Steering | 10 | 04-29-2002 06:54 AM |
