Rebuilding wheel cylinders - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2005, 08:18 PM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
Hey gang
I'm gonna be rebuildling my wheel cylinders this weekend, I got the rebuild kit (pretty sure they gave me the wrong one). I'm taking the backing plate of tomorow and the wheel cylinder(s) (I got a split wheel cylinder deal on my '50 Dodge). My uncle will hone them out then. Is there anything I need to know before I do this? I suppose all it is is put the new rubber cups back in and re-use spring and piston right? Any special method of taking these out or putting them back in?
Just checking,
Mike
Old 08-18-2005, 09:19 PM
Mrwood's Avatar
Last journal entry: My 1962 Falcon
cylinders
Why not just put new ones on. I put new ones on my 48 chevy for just a few dollors more than what a kit would cost.
Old 08-18-2005, 10:35 PM
Nightfire's Avatar
Young & Idealistic
Wiki Edits: 4
New ones for a '50 Fargo---------$75 each (I need 4 for the back, 2 for the front)
Rebuild Kits for a '50 Fargo-------$14 each
My age: 17
profession: service clerk at a grocery store
wage: not enough
Mike
Old 08-18-2005, 10:58 PM
Mrwood's Avatar
cylinders
I guess it is cheaper to get the kits. Hard to believe that they cost that much each. As long as they are not pitted to bad then you may be able to hone them out. Good luck on your project.
Old 08-19-2005, 09:24 PM
Nightfire's Avatar
Young & Idealistic
Wiki Edits: 4
Well they come from the States, and I can only get them from the middle man (Dodge City Ontario) because the company in the states only does wholesales. Well Dodge City jacks the prices up so all I can do is pay up if I wanna play.
The rebuild went GOOD I'm excited, I should wrap the rear brakes up tomorow, got brand spankin' new brake shoes for $50 (all 4 for the back).
Honing the cylinders out was an easy job, the new rubbers fit good and the boots were good too. Go the new outer bearing installed now all I need to do tomorow is inner seals ( that'll suck though) and re-assemble everything. Then move onto the front...and then I can pass saftey inspection and I'll be rollin' in sytle down the road!!!
Mike
Wheel cylinders for 58' Volvo PV444 78 monte Suspension - Brakes - Steering 6 05-19-2005 06:11 AM
Help please (wheel cylinders) raidmagic Suspension - Brakes - Steering 3 04-19-2005 06:52 PM
wheel cylinders for chrysler royal 41 cakethetake Suspension - Brakes - Steering 7 02-08-2005 09:39 AM
Wheel Cylinders ? 50chevyman Suspension - Brakes - Steering 4 03-26-2004 07:18 PM
Wheel Cylinders Sampson Suspension - Brakes - Steering 1 08-04-2003 07:58 AM
